| View previous topic :: View next topic |
| Author |
endem
Posted: Thu Sep 22, 2011 1:21 pm Post subject: '88 rear shocks |
I need to replace my rear shocks and don't know whether to use '88 Mustang LX spec units or something else as I believe the ASCs had modified suspensions.
Also can a K&N cold air induction work with the '88's engine management system?
Any info is greatly appreciated. |
| Back to top |
MRBRUSER
Posted: Sat Sep 24, 2011 12:32 pm Post subject: |
rear shocks for a 5.0 mustang lx or gt are the same. i have kyb shocks and quad shocks for front and back they worked real good is it a k&n filter or a kit _________________ 1966 lincoln convertible
1971 Chevelle convertible ls3
1987 Grand national
1988 asc coyote swapped
1993 coupe 347 stroker
2016 Shelby GT350 |
| Back to top |
endem
Posted: Sat Sep 24, 2011 8:25 pm Post subject: "88 rear shocks |
Thanks for the reply.
I'm thinking of buying a K&N kit + filter but don't know which engine management system is in my car. I read some where that they changed in '89 but that some '88s had the new system. |
| Back to top |
Posted: Sat Sep 24, 2011 11:19 pm Post subject: |
I have been installing Monroe Sensi-trac struts and shocks on many mustangs and capri's. Some lowered and or Conv. and ASC stangs and Capri with no compaints.
just my 2 cents |
| Back to top |
85asc239
Posted: Sat Sep 24, 2011 11:40 pm Post subject: |
Califorinia cars have mass air in 88 - all other cars are speed denisity. Does your car have a sensor between the air filter box and throttle body? If yes - you have have mass air and need the 88-93 kit---- if no sensor then you need 86-88 kit.
Jeremy
ps. the rear upper shock bolts are under the carpet, under the tonnuo cover. you may want to get some spray glue to put the carpet back down. |
| Back to top |
MRBRUSER
Posted: Sun Sep 25, 2011 12:22 am Post subject: |
welcome _________________ 1966 lincoln convertible
1987 Grand national
2016 Shelby GT350 |
| Back to top |
endem
Posted: Mon Sep 26, 2011 3:59 pm Post subject: "88 rear shocks |
Thanks for the replies fellas.
Jeremy, What does the sensor look like? |
| Back to top |
85asc239
| Back to top |
endem
Posted: Wed Sep 28, 2011 1:40 pm Post subject: '88 rear shocks |
Thanks for the link. Looks like I have the 49 state version as the fender mounted gizmo in that position is black and rectangular with one wire.
ps: My car is an "88, #974, Silver w blue top and interior. |
| Back to top |
