Shock Tower
bigzeke42
Shock Tower
Post by bigzeke42 »
On my 86 Eurocoupe is it common to have rust on the shock towers? And if so how do you fix them and how hard?
Zeke 86 Eurocoupe
Where exactly? Top or bottom?
If the rust is superficial: sanding, rust remover, priming and painting can be done.
If it has gone through. It'll need a patch welded in.
If it's ROTTEN down by the base frame rail...you're looking at some structural repairs and you'll probably need to yank the engine and really have somebody repair that spot correctly.
It is very common for the cars to rot out on the frame rail and it can get pretty devastating (not to mention unsafe).
Shock or Strut tower? :shrug
Mike is correct if its the strut "front of the car" if it is the rear not so common.
bigzeke42
Post by bigzeke42 »
It's the strut tower. The pass. side is the worst. Only one spot has rusted through, but rust all along the tower where it meets the frame rail. Can it be welded from the outside, just inside the wheel well?
Zeke 86 Eurocoupe
capriman86
Post by capriman86 »
Do have anyway of taking some pics?
Sometimes its bad enough that the K member would have to be
taken out to fix
capriman86 wrote:Do have anyway of taking some pics?
taken out to fix
Right, that's what I was referring to as "devastating".
bigzeke42
Post by bigzeke42 »
taken out to fix
I will try and take some pictures.
Zeke 86 Eurocoupe
capriman86
you don't want to see this
bigzeke42
Post by bigzeke42 »
Mike, Got two pictures of rust on my strut tower, in my album. It's hard to take the pictures with the engine in it. Hope you can figure out where the rust is. Let me know what you think. No rust on the frame rail.
Zeke 86 Eurocoupe
bigzeke42
Post by bigzeke42 »
Good job Mike.
Zeke 86 Eurocoupe
Thats not good,, I hate to say it but pulling the engine is your best bet if you want to fix it. You may find after pulling the engine that you could weld some steel over it but to Fix like factory will be a BIG job. And may want to find a whole clip. If it was me I would Drive it and not worry or Sale and find a Cleaner car. Sorry! but i think other would agree. I'm going thru that with a 1985 stang right now.
bigzeke42
Post by bigzeke42 »
plumkrazy wrote:Thats not good,, I hate to say it but pulling the engine is your best bet if you want to fix it. You may find after pulling the engine that you could weld some steel over it but to Fix like factory will be a BIG job. And may want to find a whole clip. If it was me I would Drive it and not worry or Sale and find a Cleaner car. Sorry! but i think other would agree. I'm going thru that with a 1985 stang right now.
I'm wondering how safe it is to drive and for how long? I just noticed the rust when I had the valve cover gaskets installed.
Zeke 86 Eurocoupe
I have seen worse on the road being driving. I would say that a front end impact is the biggest worry and thats becacuse any little hit and the rails will fold.
mandra
Post by mandra »
People often have these issues. 2 Options occur to me. I have seen many have them boxed. They cut out the rusted area, treat the remaining metal and put a nice piece of steel over the rail. If it is done professionally it will last for years without issue and won't look too bad either. The other option is to replace the frame rail. The issue with this is that it is a lot of work and if not done well can be detrimental to your nose alignment.
Best of luck
