gears????????
asc4life
gears????????
Post by asc4life »
I have stock gears in my 1986 ascmclaren covertable i would like to change them but i am not sure what it allready has or what i shuld go to.
just want to make it feel more powerfull without messing things up... it has a tag on the cover it says 206f
l27a88
602
shelbyscarab
Post by shelbyscarab »
I'm not sure if the capris were the same, but I think all the '87'-'90s came with 3.08s. Anyone? (3.55s would be nice)
Post by n20capri »
my Coupe had 3.08's! I have a set of 3.55's for sale if your interested...
Re: gears????????
asc4life wrote:I have stock gears in my 1986 ascmclaren covertable i would like to change them but i am not sure what it allready has or what i shuld go to.
l27a88
602
I *think* the l27 should be 3l27 which would be 3.27:1 Locking. The first number often is hidden by the bolt.
What does your door tag code for the axle say?
1985 Motorsport Capri
Post by 1985 Motorsport Capri »
3.27:1 were stock for automatics in 85/86.
Jason Ringuette
1985 Mercury Motorsport Capri Registry
www.Motorsportcapri.com
86capri62
Post by 86capri62 »
I personnaly have had a 90 coupe 5.0L that I switched to 3.55 with a shift kit in the trans. It made quite a difference. But after a little while I would have prefer a 3.73. The engine was still very quiet and slow running at 55 with the 3.55. it could have handle the 3.73 easy I think, with even more fun :-) and not much more gas.
86 ASCMcLaren vert (sold)
80 corvette (sold)
77 Ferrari 308 GTB(sold)
2005 MB SLK 350
2008 Rotorway helicopter
asc4life
Post by asc4life »
373s is what i think i am going to get. It sounds like it the best all around gear for my aod. I was thinking 410s but that may bee pushing it if i decide to travle a long distances. not real concerned about gass as long as it is not real bad. i heard that one company sells 390s what may be what i realy want..I have to think it threw alot before i make a choice sence it will cost me about 500.00 for parts and labor. I want to get it right the first time for that price.
cobrajeff
3.73 Gears
Post by cobrajeff »
I replaced the 3.27's in my '85 AOD convert with 3.73's, and I was very happy with the results. Also installed an "A" servo and valve body out of an '89 Lincoln LSC into the AOD.
Jeff
ASCMCLRN
Post by ASCMCLRN »
3.73's should be fine. 1986 Capri verts came with the 8.8 rear right? If not you might want to change it all together.
Nick
1986 COUPES - Full Packaged (not EuroCoupes) WITH 4-SPEED AUTOMATIC TRANNY CAME WITH 3.73:1 RATIO,
if built under D32 (ascMcLaren) order code, followed by the code
indicating that it was to be a COUPE and not a Vert.
ChuckG
Tire diameter effect?
Post by ChuckG »
I was told way back when that my coupe's effective gear ratio was like 3:31 because the 225/50s were an inch shorter than the 225/60s the RS carried.
I wonder if they calibrated the speedo for that?
I do know even up, I'd smoke a 5.0 Mustang by a good deal.
85McLaren
Post by 85McLaren »
I doubt they did. Too much work for that. That use to be a old trick people use to do. All you had to do was put a smaller tire and that would effectively increase your gear ratio.
Jason
Yes, they did redo the speedo gear.
The difference in the stock tire height and the ones asc used was like 5-7mph at about 65mph.
My speedo was always off when I was driving my car back in college and got a ticket because of it too. At that time I had the "normal" height tires.
85McLaren
Post by 85McLaren »
That would be the only thing they probably did (the speedo gear). That would be the cheapest and quickest this to do. I assume they just added the 3.27 gear in. Close enough for government work.
Jason
hummm my speedo was always off even with the right tires. it was about 3-4 mph fast at 45
