B B K K-Member support
U-MAN
Post by U-MAN »
I think I read in here,sometime ago ,A menber works for B B K ? Reason being,I have a question.A friend gave me a, near new,B B K K-Member support. But got it less rear mounting bolts. Are these Bolts special in anyway,like they would have a larger shoulder,or something?Thanks for any get back info from anyone out there.
The stock K-member rear 4 bolts are nothing special. They are about 1 1/2 - 2 inchs long. I would think that the stock bolts should work fine.
U-MAN
Post by U-MAN »
Hi, I thank you for the reply on the bolts.Sounds like a Sat. job. Have to get it out of the way,before the grass starts to take it's place on the job list.
BRYAN ROGERS
Post by BRYAN ROGERS »
Sorry I've been ignoring the McLaren for a while and haven't visited in a log time....
The bolts on the rear of that 4 point G load brace are much longer. They are just regular bolts with a simple washer to keep the head from tearing into the powdercoat finish. The front bolts are the same as stock. They just go through the brace and you're done.
'06 Z4M Roadster
'88 ASC McLaren.
'93 Cobra.
'95 Cobra.
'07 Kawasaki Z1000.
U-MAN
Post by U-MAN »
HI. I really do appreciate the bolt info.,Just could not pass up the K- Menber support,as the price was right.Been running your headers also,they have worked out real well.Thank you, once more Bryan.
BRYAN ROGERS
No problemo.
The 4 point G load brace was a good piece. It's been discontinued for a while due to low sales but it really worked on the cars I've used them on.
'06 Z4M Roadster
'88 ASC McLaren.
'93 Cobra.
'95 Cobra.
'07 Kawasaki Z1000.
