wanted: 1985 mclaren conv. d/s door glass
Buy, sell or post an ad you've seen about ascMcLaren cars or parts.
pro321a
Post by pro321a »
Need a driver's side door glass for a 1985 mclaren conv. Does it interchange with anything? Any help would be appreciated! Can e-mail at bailey321a@juno.com.
RARE-ASC
Post by RARE-ASC »
No these were custom made at ASC.
-DAVID-
MY KEEPERS!
2003 SILVER MERCURY MARAUDER 320 HP 32V DOHC.
2013 FORD F150 RAPTOR "TERRAIN TAN" 4X4 CREW CAB & LIFT ON 37s.
2016 SHELBY MUSTANG GT-H HERTZ EDITION #82 OF 171.
1995 F-350 CREW CAB DUALLY POWERSTROKE FULL BANKS KIT!
Will 84-90 asc glass interchange?
The only sure place to get one is Hank in Florida (www.ascmclaren.com).
Beyond that, occasionally a wreck is found in a jy and parted. Check ebay, there were pieces of a white one on there a while back.
knsstang
Post by knsstang »
What is the difference between mustang glass and mclaren glass? Can the glass be adjusted up or down from the bolt that holds it to the rod inside of the door.
2013 Kia Optima (275Hp)
2012 GMC Yukon Denali (403Hp)
Post by Sandy »
I think the door glass was made by Ford, and packaged into the trunk, FOR ascMcLaren. But, in this case, I MIGHT be wrong! Why do i say that?
Because I have seen the Ford *auto lite" insignia in some McLaren 'Verts door glass. But, I do not have a part # AND it's not listed on my Ford supplied listing, so, 'ya, it's sorta kinda a mystery, or "Grey Area" ~
I too would like to know.
McLaren glass is cut at a totally different angle because they bent the a-pillar back 10 degrees.
You can't cut Mustang glass to fit as the glass is tempered and will explode on you. You can de-temper glass, cut and retemper it but it would probably be cheaper to just get it from Hank.
86capri62
Post by 86capri62 »
Just to let you know guys that I did cut a tempered glass myself in the past with success. All you need is a LOT of patience. Used a zip cut wheel and slowly go into it and cool it with water. After I ground it smouth rounded with a grinder again with time and patience. Finally smooth it with orbital sender and fine grit. One too hard impact while in the process and it falls in million pieces. The secret is work very carefully and never get a HOT spot while cutting. Good luck if you try!!
86 ASCMcLaren vert (sold)
80 corvette (sold)
77 Ferrari 308 GTB(sold)
2005 MB SLK 350
2008 Rotorway helicopter
tfs2121
Post by tfs2121 »
i will try to remember to call howard sunday and see if he knows who it came from.
1985 ASC McLaren Coupe
pro321a
Post by pro321a »
Thanks for all the replies. Look forward to finding out what asc used originally.
pro321a
Post by pro321a »
Still looking for a door glass. Anybody have any leads?
wayne
door glass
Post by wayne »
are you still looking for the convertible door glass?
wayne.
