TO MIKE NEGUS and others.
foxchassis
Post by foxchassis »
If it was separate and additional, what did it consist of, and why was the code only on '82 through '86 tags?
I have seen tags from several '85 and '86 McLarens that do not have NLR.
I have yet to see a tag from an '82-'86 SSP or an '84-'86 SVO with NLR.
85McLaren
Post by 85McLaren »
Like fox said above....
My 85 doesn't have a NLR. And back to the original question that we are trying to find out - What is the difference between Mike's Car and mine (for example) ?
Mine had factory exhaust also.
Jason
Sandy wrote:Reading from a Ford manual on line, I came across this:
....(on Ford production engines and dynamometer control applications.
NLR (noise Level Reduction) NLR, as it's called.......
Link?
It does appear that NLR is a very common engineering term in mechanical engineering circles.
Sounds like we have something here. I wonder what it is exactly.
Sandy, do you know what ST means? It is on cars from 79+.
Not a clue on ST
DF?
KHummel66
Post by KHummel66 »
ST - Steel bumpers
DF - Blackout/painted door frames
Really ?? :?:
foxchassis
I can tell you that from the tags I have data from, 'ST" is not "steel bumpers" and 'DF' is not "black" or "painted" door frames.
KHummel66
Post by KHummel66 »
I hate it when I get bad info. Even more so when it seems to be supported with the specifics of my own vehicles. Grrr
If your info came from the internet...we already looked there :D
I know " DF " !!
Those were
the grades I
got in High School
Math !! :x
KHummel66
Post by KHummel66 »
OK, so I didn't keep myself current on the buck tag threads at FEP before posting those code explanations - sorry, my bad.
BUT, how about these:
ST = Power Steering
DF = Disc Front (as in Power Front Disc brakes)
FoxChassis - how does this fit will all the data you've been collecting on FEP??
foxchassis
Nope, not those either.
"ST" is also not "Sport Tuned" exhaust.
Could one of those be for a quick ratio rack?
