Marcahl Fog Lamp Bulp
2000mileRS
I have one fog lamp that is not working. I removed the lamp from the mounting assuming I could open up the lamp at the housing and replace the bulb. Two things happened. 1. the connection to the fog lamp from the harness was impossible to unplug. Two, I removed the two screws from the black housing assuming I could pull that off along with the lense. This was not the case. Can I replace the bulb (h2) on the fog lamp???
86ASCCoupe20
2000mileRS
Marchal fog lamp
Yes, I have the bulb, my question is how do you take apart the foglamp?
86ASCCoupe20
2000mileRS
Thanks
I got them open, they were sealed up pretty good.
