Marcahl Fog Lamp Bulp
2000mileRS
Post by 2000mileRS »
I have one fog lamp that is not working. I removed the lamp from the mounting assuming I could open up the lamp at the housing and replace the bulb. Two things happened. 1. the connection to the fog lamp from the harness was impossible to unplug. Two, I removed the two screws from the black housing assuming I could pull that off along with the lense. This was not the case. Can I replace the bulb (h2) on the fog lamp???
86ASCCoupe20
Post by 86ASCCoupe20 »
You can buy that bulb at most parts stores. Its a wagner BP1255/H2
Stan
1986 ASC Mclaren coupe #20 of 114.
Black with gray interior and stripes.
65,227 miles. Pop up sunroof car.
302 5 speed.
2000mileRS
Marchal fog lamp
Yes, I have the bulb, my question is how do you take apart the foglamp?
86ASCCoupe20
Oh. I did both of mine. Itcame apart pretty easily. You do have to fanagle the metal part that clamps on to the bulb with a screwdriver but besides that it was easy to do.
Stan
302 5 speed.
2000mileRS
Thanks
I got them open, they were sealed up pretty good.
