Trunk!!!
- Tx Trooperstang
I keep my McLaren's battery disconnected when in storage. Every single time that I slip the battery cable over the post..... my trunk pops open !
Why you will not at least try that, I do not understand.
- capri50asc
Battery issues/ Storage
Guys
You need to use Battery Tenders model 021-0123. These units keep the battery fresh and charged at 100% removing the battery cable is not good on the ECM , as it erases the data for the engine management system and could take a couple of days of different driving habits to gather new data. I have the Battery Tenders run from Oct-March Its also easier on the charging
system.
'86 Capri Vert #0082
'86 Capri 5.0L RS
'73 Cougar
07;Honda Ridgeline RTL
'10 Ford Fusion
system.
'86 Capri 5.0L RS
'73 Cougar
'10 Ford Fusion
My God...He still will not try what I told him to do !!
The "thingie" in there is "stuck" and if if if if he tries what I
suggested, it will unbstick it and it WILL work !!
I mean, if ya ask for help... at the very least try it
inyczoddjobz
- Tx Trooperstang
Re: Battery issues/ Storage
Just ordered one. I need this so bad. Thanks for the tip. Only $25! I got the Junior which is just to keep it topped off.capri50asc wrote:Guys
system.
The "Plus" is just a faster charger. I have a full blown battery charger for that.
Battery
I have 3 battery tender JR.s, they work great. They also keep that battery from oxidizing the plates inside. My 03 Mach still has the original battery and its been on a tender most of it's life.
Just beacuse its small doesn't mean it takes a lot to get a dead battery going. I put it on my dead 5 year old Kmart battery in my 69 which had not been started for more than a year and was able to start after 1 day.
Charging a battery too quickly oxidizes the plates as well.
In your McLaren's compartment (s) inside the car in the compartments just behind your 2 bucket seats, do you see a thin plastic wire? If so, pull it. It is a MANUAL release to open the trunk.
