Need new Tranny
Need new Tranny
so my U-joints went out and made a mess of things with my tranny. I wanted to confirm with you guys is our (86 convert) is the AOD? To my surprise I'm having a hard time finding one on the Middle TN area.
1986 White vert McLaren# 196
- capri50asc
- Contact:
Transmission Tip
Your car has the AOD transmission. There is three aftermarket companys that sell aftermarket AOD transmissions:
B&M racing and Performance $1,750
Contact B&M directly
TCI Automotive has two versions both around $2,025
Contact TCI through Summint Racing or Jegs High Performance
Performance Automatic Racing $2,200
All these transmission are built better then the factory units from Ford Motor Company. With features like:
Stronger fricton Plates
Kevlar overdrive bands
Heat treated Vasco shaft
Cooler operating temps
Improved lubrication
Give them a call!
Chris
Give them a call!
Chris
Re: Need new Tranny
The front seal went in my '89 AOD at 180,000 miles in September. I had the local transmission shop rebuild mine for $1,050. I wanted to keep my ASC all matching. 1,000 miles so far and running very well.
Havoc wrote:so my U-joints went out and made a mess of things with my tranny. I wanted to confirm with you guys is our (86 convert) is the AOD? To my surprise I'm having a hard time finding one on the Middle TN area.
Hank
Phoenix
'89 ASC #176
'87 ASC #134
'85 GT
Phoenix
'89 ASC #176
'87 ASC #134
'85 GT
