Well, I just had to break something . . .
75coug
Post by 75coug »
I decided to take the '86 to a car show this weekend, and while moving it around my storage area, misjudged a curb and tore off the air dam. Pardon the pun, but damn.
It was interesting to see how the air dam was originally slapped on top of the existing bumper cover, as opposed replacing the stock unit.
Anyway, I need to figure how much it will cost to replace, determine whether to replace it, blah blah blah. Aside from Henry, does anyone know of a place to find a new unit?
Robert
1989 ascMcLaren convertible - royal gold
1986 ascMcLaren convertible - red
1984 ascMcLaren convertible - white
How bad was the old one mangled?
You might be able to save it. I'm not a big fan of the old air dams that are very brittle but if it's just the air dam you need put back on, it might be repairable with some work.
Other than that, Henry has repros that are made from a very strong, easily repairable material. No one else will have one unless you get lucky and someone is abandoning a project.
75coug
Post by 75coug »
It is in three or four pieces (brittle indeed - the impact was minimal), so repair does not appear to be an option. Arggh.
Robert
Honestly any original ground effects still out there are very much on borrowed time.
Now that you have the cut-away version of the air dam, get some pics of how the original bumper cover is cut and how the air dam is mounted.
75coug
Post by 75coug »
negusm wrote:Honestly any original ground effects still out there are very much on borrowed time.
I definitely will.
Robert
n20capri
Post by n20capri »
Man that sucks...sorry to hear...
The new one from Hank comes with the side pieces but if you happen to need just them I have a decent set...
One is slightly cracked but easily fixable
Mike
86 9L SVO
www.mikemartinelli.com
www.baldguydesigns.net
Post by Sandy »
:cry: Sad 4 U
Post by plumkrazy »
Mike,
if Robert dosnt want/need them what would you want for them? I'm pretty sure I short those for mine 86 ASC. It's still in the collecting phase.
n20capri
Post by n20capri »
plumkrazy wrote:Mike,
idk what they are even worth...$100 shipped?
Mike
86 9L SVO
75coug
Post by 75coug »
Thanks for the offer. It looks like I will not need those, so plumkrazy, they are all yours.
Robert
86capriasc
Post by 86capriasc »
I did the same to my front end. Instead of buying new I repaired it along with the cracked side and rear pieces, so far they have held up well.
I have pics of the process here.
http://s688.photobucket.com/albums/vv24 ... /?start=20
1986 ASCMclaren #108
stock E7 short block, explorer intake, 65mm TB, home built Gt45 turbo kit, 3.08s, Borla cat-back, '05 slot maf, Gt-40p heads, TFS1 cam, 80lb injectors, E85, Qaurterhorse tuner.
75coug
Post by 75coug »
Impressive work. Thanks for the pics.
Robert
