New owner of 87 mclaren convertible...trunk opener???
porshapower
Hello Guys
So I have a cable sticking out between the convertible top cover and the trunk lid that you pull and the trunk opens up. Was this cable attached to a latch somewhere? I also have the button for the power trunk popper in the glove box and it makes no noise when I push it. Was the power deleted and a cable pull system installed on the mclaren? Thanks
- mustang marty
- Contact:
There were emergency release cables for both the trunk and tonneau cover in case the battery was dead. They were located in the storage boxes in the package shelf. In my 85, the trunk is on the drivers side and the tonneau cover is on the passenger side. The cable has a loop on the end to make it easier to pull.
birdiestobehad
I would guess that a previous owner had some sort of issue with the power release button in the glove box. Possibly a short , bad relay, bad motor, etc. and decided not to fix it since they could use the release cable.
Then after time the cable broke broke, so instead of replacing it, they pulled it through the box and ran it up between the cover and trunk lid as you have it now.
A couple of years ago my release cable broke and I didn't replace it until I started having intermittent issues with the power button. I posted my process with a few helpful hints. Here is the link:
http://www.ascmclaren.org/phpBB/viewtop ... 5255#35255
Terry M.
1986 'vert #118
1986 'vert #118
- capri50asc
- Contact:
Cables in a 86 ASC Vert
The 1986 ASC Capri Vert has three release cables,Kentennis wrote:The cable behind the driver is for the trunk release. The cable behind the passenger is for the gas tank release. Those are the only 2 on my '86.
The one behind the drivers seat opens the trunk
The one behind the pass, seat opens the tonneau cover
In the trunk under the mat is a cable with a t handle hooked on it
this opens the gas door.
Hope this Helps
Chris
porshapower
- capri50asc
- Contact:
Release Cables
If you need new release cables Go to>>> This home page at ASC McLaren.>>>>>>Go to Paradise Automotive.>>>>>>>> then to Parts for sale>>>>>>>then Interior parts>>>>>>>>>Emergency Release Cables>>>>>>>Part number #2627 >>>>>>>>>>>>>>>$75.00
Good Luck
Chris
Good Luck
Chris
birdiestobehad
