Windshield trim
zanrock
Windshield trim
Post by zanrock »
I have read about doing the windshield trims and read that some did not fair so well. I had truoble with mine (coming loose here and there) thats been on forever and after doing research and talking to 3m reps i fixed mine and so far no problems at all. After removing the trim carefully wich took about 2 hours, i removed all of the old adhesive and acetoned the inner trim and denatured alcohol the cars A piller. You leave the old epoxy ASC used to take up the gap between the trims inner and A piller. (That seems to me what gets removed and the trims flys off later on). Now with help from a friend i roll out a new bead at the edge like where the old one was using 3m's auto glass window weld ribbon 3/8dia. (No more7/16) number 08612 then run a small bead of medium strength auto glass adhesive by 3m number 08693 on top of the rolled bead you just laid out so no water goes inside the trim when it rains. Now with the same medium adhesive number 08693 i ran it in criss cross patter on the old epoxy about 3/8 high as quickly as possible (the rep said about 20 min working time, the tube does not say anything) when done, press the trim back on the car, wiggle it a tiny bit and i used 4 clamps for 1 hour and so far 2 months later and 170 miles the trim is solid. I suggest that if you need a new windshield do it before doing this as it probibally wont be removed easily for many years again. This worked for me and i hope this helps you. Rich
Great info!
zanrock
Windshield trim
Post by zanrock »
I forgot to add along with the old epoxy next to that there was old ribbon on both side of the A pillers, remove the old and replace with the new. I dont beleive i left any more out, but do note there was nothing along the top section of the trim. So unless you see something do whats needed, like repair etc.. Rich
CocoLoco
Post by CocoLoco »
Thanks for the great description. I will need to do this to my 85 one of these days.
1977 Red Bonneville Coupe
