Interior door panel light & tie-rod ends
Hello all... I've tried searching the resources and the archives but can't find what I'm looking for. What type of tie-rod ends were usedon the 89 ASC? What type of vehicle can I that interior door panel light out of. I believe that I read it was from a Lincoln, but I don't know which year and make. Can any one help?
2012 GMC Yukon Denali (403Hp)
4-barrel Mike
4-barrel Mike wrote:Tie-rod ends ???
Courtesy light: http://www.ascmclaren.org/phpBB/viewto ... ht=Lincoln
Thanks a lot... That helped quite a bit. Trying to get my car back in order.
I'm torn between buying new( different type) or reupholstering mine.
I found the tie-rod information( Turbo Coupe) and 1 inch lowering springs... http://www.ascmclaren.org/WhatIsAnAscMcLaren.html
4-barrel Mike
Figured I'd use that as a starting point for lowering my car. You think the suspension on the 89's are the same as factory mustang? Springs, shocks, tie-rod ends, struts?4-barrel Mike wrote:In that paragraph, he's talking about '85-86 Capri coupes. I don't think that it applies to Mustang convertibles.
Stock Capris and Stock Mustangs from Ford were 100% identical in the suspension stuff.knsstang wrote:Figured I'd use that as a starting point for lowering my car. You think the suspension on the 89's are the same as factory mustang? Springs, shocks, tie-rod ends, struts?4-barrel Mike wrote:In that paragraph, he's talking about '85-86 Capri coupes. I don't think that it applies to Mustang convertibles.
Pretty sure the only thing asc might have changed for the Mustangs would be the springs. Everything else would be the same as Ford. But I am not a vert expert.
