86 Capri 5.0 Vert VCL pics?
Tchampag
Post by Tchampag »
Team, my vehicle cert label is destroyed and unreadable. Can anyone pass along a photo of their VCL?? I’m after the GVWR, GAWR REAR, GAWR FRONT, RESERVE WEIGHTS (F0000/R0000), and SPRING CODES.
thanks for any help!
4-barrel Mike
Post by 4-barrel Mike »
FWIW without posting a pic, from my 04/85 roadster:
GVWR: 4060LB/1841KG
FRONT GAWR: 2131LB/966KG
REAR GAWR: 1949LB/884KG
No reserve weights/springs, probably because:
VIN: 1MHB....
TYPE: INCOMPLETE VEHICLE
Tchampag
VCL Data - continued
Post by Tchampag »
Mike, thanks so much. Terrific. Hopefully others will reply with their data, especially ‘86 verts... again, thanks!
FYI, Marti Autoworks should be able to recreate the exact label. He has the data.
Have you asked them?
Tchampag
VCL
Post by Tchampag »
Thanks Mike - working that angle now.
