New Top
New Top
Just got my new top installed. The fit is much better than the last one which was an original replacement. This top was made by EZ On.[/img]
Thanks for the info. Glad people are still keeping these cars going.
Driving
I have not driven my car much over the last couple of years. First it was the radiator. New one was bad, overheating. Then it was the water pump. After that, there was a big hole in the roof. With all that fixed, I plan to drive the car a bit. At the most I might do 3300 miles a year.
The gas mileage has not been great so I thought I would replace the cfi injectors. The rebuilt injectors were duds. Not even a start up. These things are not easy to find. I found an NOS set in my inventory and they worked just fine. Will have to see if the mpg improves.
I also have some big holes in the y pipe exhaust after the cat. There does not seem to be any replacements. It sounds good.
