sun-visor rod needed for 1985 ASC convertible
mandra
Post by mandra »
I didn't think these were custom but it appears they might be. https://photos.app.goo.gl/fZFM2CnyFcGE81tZ6 does this look familiar to anyone?
Thanks,
I could have this re-chromed but if I could find new I would prefer that route.[/code]
U-MAN
Post by U-MAN »
Hi, When I redid my visors, I got a complete set off of "EBAY". The set I bought came with everything. That was visors and hardware. Seems like any fox body visor mounting rod should work. The reason I did my change over was to trim the visors down , so they would not be in the way. Put a write up on this web site awhile ago.
U-MAN
Post by U-MAN »
Hi, We talked about the "visor fix " on Jan. 4,2017 It's under " ANNOYING SUN VISORS". So if you want to look it up, that's what it is under. I hope this helps you out . Good Luck !
mandra
Post by mandra »
Thanks for all the replies. Turns out I need rods from a 1985-93 FOX Body with a sunroof or T-Tops. The others have a different shape.
Now to figure out where to get the oddball tan carpet that runs on the sides of the console and rear bucket compartments. This resto is fun but infuriating at times.
Visor
I would expect the sun visor to be 85 and up hatchback. I know the 84 hatchback hard a 3 screw mount and the 85 asc has a 2 screw mount. If different, it should be on the Ford parts list.
