Correct ground effects?
massrog
Post by massrog »
Hello I am looking at purchasing this '85 convertible but I can't find any images of this ground effects pkg. on any other car. Can anyone here identify it. I would greatly appreciate any input!!!
Thanks,
RogerG
KHummel66
Post by KHummel66 »
None of that is correct.
1986 ASC vert - #86-0001
1986 ASC vert - 3.8SC v6
1985 ASC vert - Black/Tan/Tan
1985 ASC coupe - modified
1985 ASC coupe - roller
1983 Crimson Cat V6
1966 Cobra replica
That is an aftermarket setup for a Fox Mustang but not an asc.
Looks nice though.
massrog
Post by massrog »
negusm wrote:That is an aftermarket setup for a Fox Mustang but not an asc.
Looks nice though.
Thanks mike! Now the question is if a "modified" (otherwise stock) 26k car is worth $11,000? I had no question until I noticed the different skirts. What think you all? It needs a top and a flasher along with a good detail (maybe a seat cover).
https://postimg.cc/gallery/RHLK52b
IMHO, if it runs right and it needs minimal work, I think it's worth it.
If it needs an engine/engine rebuild...then no.
Parts and labor add up fast to get a car up to snuff.
Expect to pay $2k for a top and $2k for seats.
massrog
Post by massrog »
negusm wrote:IMHO, if it runs right and it needs minimal work, I think it's worth it.
Thanks for weighing in! Like I say it needs new plastic in the top or a new top (I'll likely do the top) and dye on the driver bolster (the leather is fine, finish flaked). The most worrisome thing to me is a draw on the battery as electric work is time consuming. The car runs/drives fine other than flat spotted tires.
Has new struts/shocks, rebuilt carb etc.
Electrical work on these cars is easy. No computers. Just 12v here, ground there.
Parasitic draw is super easy on these cars. Just put an ammeter in-line with the battery and start pulling fuses. Whatever circuit stops drawing the parasitic draw if your circuit.
It's almost always an aftermarket sound or security system.
massrog
Post by massrog »
negusm wrote:Electrical work on these cars is easy. No computers. Just 12v here, ground there.
Thanks very much for the advice! I guess I'll invest in an ammeter tomorrow!
Well, get a MULTIMETER and you'll get a voltage meter, ammeter and be able to test for continuity. I'm not sure if they sell a basic ammeter except maybe for commercial use.
Have you ever done any electrical work? I suggest a bunch of YouTube videos. I would start with basic multimeter functions and end up with parasitic drain.
I would learn how to do the "in-series" parasitic drain detection method instead of adding up all the voltage drops at the fuse box as that is a bit more complicated.
massrog
Post by massrog »
Well I decided I'd try a test light and checked every circuit in the fuse box and no luck. Every one lit the light when checked without the fuse. The one thing I found was a 15 amp in the warning indicator lamps socket which is supposed to have a 10 amp. I guess I will have to get an appt with the local auto electric shop as I don't want to tear into thing any further as I have no expertise.
massrog
Post by massrog »
After some thought I figured I'd ask if there is any other fuse box for the convertible top systems or if they were incorporated into the "factory" wiring? As stated above I removed each fuse in the "factory" box and still had a draw on each so I wondered if ASSC might have added one somewhere else?
massrog
Post by massrog »
I don't know if anybody here remembers the saying :"Kilroy was here" from WWII but I would like to change it to "Bubba was here". Most of you will know what I mean. while under the dash I noticed a piece of perforated steel strap bolted to the frame under the center of the dash
Image and just below that tucked neat as you please between the tunnel and the frame but not plugged into anything was what I've since discovered my black box relay
I'm guessing I've likely found my "short".
Yeah, that looks suspect to me.
If I were a dictator, electrical modifications of cars would be punishable by death. People just hack and slash electrical systems then wonder why it has a parasitic drain or are popping fuses.
Any higher amp fuse that is put in to fix a blown fuse is done by an absolute moron.
This is how cars burn to the ground.
Glad you found it...or most of it. Never know where Bubba will strike next!
