I saw them being made in Michgan
- merk23literturbo
- Contact:
I used to work for a company that supplied Ford and got a chance to go through the small plant in Michigan while they were making ASC McLaren convertibles. Interesting to see how much they cut the structure to make a convertible. They actually cut the windshield frame and dropped it back ~20 degrees(?). The car was gutted and the chassis was sprung upwards at the B-pillar while being held down. Then they welded in reinforcing brackets in the rear seat area. When the chassis was released the door had a nice straight gap unlike some other convertibles that ASC made during the 80's. I think these brackets were a modification that was made during the production run to fix some dropping door problems.
Also interesting to see them cut the quarter panels for the convertible top. We walked through a storage area that had all the OEM interiors stacked up.
Really interesting was seeing the painter re-spray the shells by hand with Sikkens Urethane paint. The paint jobs should last quite a while since they were done correctly with Urethane paint and undercoats.
Just found your site and thought I'd share some tidbits with you.
Watched them being made
- merk23literturbo
- Contact:
The day I was there I only remember Capri's being cut open. They gave us a lot of literature, I'll see if I can find any of it. There was some guy named Roush that I talked to for a while, he seemed to know a lot about the engines, but he wouldn't let me take one for a test drive. I guess he must have been an accountant or something.
If I remember correctly they blended the color into the doors on the metallic cars. So if you have a Mil gauge the solid color cars should have less paint on the doors and front than they have on the rear panels. But the metallic cars should have more paint on the front doors and rear panels than they have on the front end. They painted the A-pillars on all the convertibles since they cut them open.
- Sandy
- Contact:
more more more more more more PLEEZZZE
We are ALL ears and hushed
- merk23literturbo
- Contact:
- Sandy
- Contact:
So you saw the 1986 Mercury Capris being made. I have one of the ascMcLaren Capri COUPES. # 109 of 115 with 646 miles on it. It's Charcoal Grey with the orange rims & decals. I show it in shows where it's always a huge hit.
- merk23literturbo
- Contact:
- merk23literturbo
- Contact:
I just remembered something. ALL of the cars came in as hard tops. They cut off the roofs of the cars at this mini-plant to make them convertibles. During this time all convertibles were made by after market companies so that the manufacturer would not have to worry about being sued if someone got injured in a convertible.
(Lawyers enter the scene again.)
- Sandy
- Contact:
You mean Hatchback coupes, right? With that big back bubble glass window ?? Yes?
- merk23literturbo
- Contact:
- merk23literturbo
- Contact:
OK, I finally found the brochure from the factory. It appears that we were at the plant that was making the SC convertible model. I can scan the brochure but you probably already have this one on somebody's web site. If someone can give me an Email address I will scan all 4 sides and send them to you.
(They list Air Horns as one of the options? That must be fun at a crosswalk.)
(Maybe I watched someone's bright red convertible being painted that day.)
- merk23literturbo
- Contact:
