I have the list you are speaking of. However, It's just too long to type here.
A quickiee follows.
Start with GS V-8, but it gets the 4-Speed with overdrive or the 5-Speed Manual. (Neither available on a "normal" GS ~)
Blackout treatment on window frames (doors) and around front/rear windows
Unique exhaust system & muifflers (from the RS)
Being a GS it got the GS front fascia, which would be cut to install the McLaren air dam and McLaren-Installed Hella Foggies.
Since a GS; there was no side F/R charcoal panel, yet a delete code was on the build sheet. This MIGHT indicate that at SOME time SOME RS models MIGHT have been used.
Black-out exterior key holes & Hatch key hole.
Black-Out wiper arms and related hardware.
Delete all GS emblems
Install RS Seating with Dk. grey piping rather than red-orange piping.
(Here goes Mike's hiar on back of his neck, now.....)
Utilize flat black antenna & base & interior door panel switch gear for Pwr. Windows & if so equipped, Pwr. Door Locks and well as finishing plates surrounding the switches.
Utilize RS Steering wheel
Now, that said.....
You should see the PROPOSSED sheet showing the items for a McLaren Coupe that went to the cutting room floor.
Perhaps Fredzilla can locste that! I put it here, a long time ago. Mike, HELP !
Oh, and yes, the Midnight Blue Metallic was a
GS ONLY exterior paint color.
Actually, if ya think about it, the ascMcLaren (convert also) were really their own build, and NOT a GS nor a RS. The Verts even have a sticker on the driver's door jamb stating INCOMPLETE VEHICLE (This is 99% on the 1MH) beginning VINS, much much moreso than on the 1ME beginning VINS.
Don't go there!
