Trunk!!!
inyczoddjobz
Trunk!!!
Post by inyczoddjobz »
I have a 89 asc mclaren mustang and the trunk release button clicks but does nothing...i tried the cord but the cord seems to be not connected right so thats useless.....and i cant find a key hole for the trunk so im guessing it doesnt have one...can anyone help?
There is no keyhole! The "hole" that was where the key hole was used for for the center stop lamp wiring, as when it was a 302 V-8 "LX" 2-door sedan.... the center stop lamp was mounted inside on the rear package shelf.
Now then... look inside the car, brhind the 2 front seats. In one of them (I 4-get whicj one....) you should see a nylon plastic thin "wire" carefully pull (NOT YANK) it and it will open your trunk. My guess is that the plastic button is the problem......Sandy
inyczoddjobz
hey Sandy thank you for replying so quickly..but i tried the cord and it dont work
either.. tried both cords just incase nothing i think im in trouble
Tx Trooperstang
Post by Tx Trooperstang »
Have you tried to have someone pull up on the trunk as you press the button?
Tom
Coming soon # 1079
hanksgt
Re: Trunk!!!
Post by hanksgt »
Do you hear the relay click when you press the button? How about gently pressing down on the trunk to relieve the pressure while some one presses the button?
Hank
Phoenix
'89 ASC #176
'87 ASC #134
'85 GT
My trunk release is behind the driver's seat. The one behind the passenger seat is for the gas filler cover. And the ones in min are woven wire similar to aircraft cable. And they're hard to pull! There are 2 buttons in the glove box that open them too. Mine both work and I can open the trunk, remotely, with my 'clicker.' That works too, but I only have 1 clicker and cannot find another one anywhere! I sure would like to have 2.
inyczoddjobz
hey thank you for replying and yes ive tried everything i had someone push down while i clicked the button..=/
inyczoddjobz
Lol Ken i was just frustrated and i pulled both gas and trunk cables lol i wish there was 2 for the trunk...1 back up for the back up cable
I understand!!!
I have a problem getting my top to stay latched when it's up. The little probe in the back 'pops' the back of the top open when I hit a bump. The adjusting screw came loose and backed all the way out so I have no idea of where it was before. I'm slowly turning it down so I don't break something. Getting very close now. Adjusted it again yesterday and took it for a 100+ mile run but haven't put the top back up yet. Hell, we live in Florida and the car lives in the garage. Not sure of the mileage exactly but it's somewhere arounf 23, 530. Doesn't hurt anything when it's not latched. water can't get in and the only thing is, someone could just lift up the back of the top and steal anything they want. Of course, cutting the top to get to it would be worse!! We don't keep anything of value in there anyway! Just don't take the whole car!!!
Okay, let me open your trunk !
Do this:
Open Hood
Disconnect one (does not matter which cable to slip off)
Wait 5 seconds and reconnect the cable.
Trunk is now open ! :lol:
mustangjim
Trunk
Post by mustangjim »
Not sure if its possible, you vert guys would know. Can you remove the package tray with the top up to gain access to the trunk? Did the manual pull cable break or just didn't do anything? Manual releases with these cars ages tend to freeze up over time. Is there an audible click when the relay button is pressed? Could be a possible blown fuse? I'd check the fuse box just for kicks.
Best of Luck - Jim
1986 ASC McLaren Eurocoupe #19 of 47
1979 Mercury Capri Ghia - Sold 2007
1991 Triple Black LX - Sold 2005
1992 White & Gray LX - Sold 2004
1996 Moonlight Blue GT - Sold 2003
1989 25th Anniversary LX - Sold 2003
1984 Mercury Capri RS - Sold 2002
Trunk
Have you tried replacing the battery in the remote?
inyczoddjobz
Thank you for all the replys.
when i click the button in the glove box you can hear clicking but doesnt do anything..ive had people push down while clicking and lift up while clicking...did the same thing while pulling the cable doesnt do anything and i pulled it hard..the fuses are fine...and i do not have a car remote for the car..and Sandy i didnt understand your last post...again ty all for replying
Diidn,t understand ?????
Open hood
Disconnect the battery by slipping off one (either one) cable off of its battery "post". Then when completely off and in your hand, replace it onto the battery post that you slipped off from. The trunk should open
KHummel66
Re: Trunk
Post by KHummel66 »
mustangjim wrote:Not sure if its possible, you vert guys would know. Can you remove the package tray with the top up to gain access to the trunk? Did the manual pull cable break or just didn't do anything? Manual releases with these cars ages tend to freeze up over time. Is there an audible click when the relay button is pressed? Could be a possible blown fuse? I'd check the fuse box just for kicks.
Best of Luck - Jim
Maybe ... if the seats were removed. The 'package tray' is actually two parts - the flat shelf with storage compartments, and the surround. The shelf will come out, possibly with the seats in place. The surround is another story. I'm not sure if it would fit through a doorway or not, even with the seats out.
1986 ASC vert - #86-0001
1986 ASC vert - 3.8SC v6
1986 ASC vert - Silver/Black/Gray
1985 ASC vert - Black/Tan/Tan
1985 GPIV - The Official Pace Car
1985 ASC coupe - modified
1985 ASC coupe - roller
1983 Crimson Cat V6
1966 Cobra replica
