Green box in trunk clicking
Post by 86MclarenCapri »
While working on cleaning up the trunk this weekend, I bumped some of the wires going to the pull down motor and the green box that everything plugs into clicked. I wiggled the wires and it kept clicking.
I'm wondering if this may have something to do with my battery drain. Everything electrical works in the back end of the car, so I'm not overyl concerned, I just don't want to burn it out.
Any suggestions on how to troubleshoot it? Has to be a loose wire somewhere.
lobasty
Post by lobasty »
Did you find any solution for it? I'm having the same problem on my car.
Box
The green box should be for the relays which disable the tonneau when the trunk is open. There should be a white switch by the left trunk hinge. Maybe the wires are loose at the switch.
