86 engine performance
Posted: Tue Jan 20, 2026 1:31 am
by Denbob55
Hi all. I own an 86 Merc convertible in decent shape, but was underwhelmed about the performance. So I put on an 87 HO upper manifold with 70mm throttle body before I discovered the speed density FI isn't able to compensate for the extra fuel/air mixture. Now of course I have irregular idling. Before I reverse everything is there a trick to getting the ECU to recognize the performance upgrade? thanks
Re: 86 engine performance
Posted: Wed Jan 21, 2026 2:18 am
by ChuckG
It should be okay with a 65MM but there are several people who can burn a new EPROM for you. Pete Campbell in Michigan is certainly qualified to do it.
Posted: Tue Feb 24, 2026 7:13 pm
by Denbob55
I found a mechanic who was raised on 80s Fords. It is as many of you say; check vacuum leaks, test sensors, check firing order. The last guy switched two cylinder wires, the TBS voltage was set too high, and the vacuum hose to the MAP sensor was disconnected. Now she runs fine as set up with the 70mm throttle body. Next we're going to check timing and go from there whether we need EPROM or not.
Posted: Tue Feb 24, 2026 7:25 pm
by Denbob55
Hi Chuck, I can't find Pete Campbell on this site.
Posted: Wed Feb 25, 2026 3:52 am
by ChuckG
He's in the Facebook Coupe group. Livonia, Michigan
Posted: Wed Feb 25, 2026 3:57 am
by ChuckG
Posted: Sun Mar 01, 2026 1:43 am
by Denbob55
Not to be a pain, but I was thrown off FB. I have no idea why, but if you find a minute maybe you can ask him for an email. if not then my loss
Posted: Mon Mar 02, 2026 4:29 am
by ChuckG
I sent his number via PM. I don't have an email.
