Oh well had to vent these things make me crazy. Last time I broke one of the wire looms
How many people have had to replace the Valve Cover gaskets?
All of my 5.0's have needed replacement of the Valve cover gaskets. The one I am doing tomorrow is on my 85 ASC Vert. 18,895 miles and the VC is leaking like mad. Darn thing even has the original wires on it and they are fine. Is it just me?
Re: How many people have had to replace the Valve Cover gask
Are you using cork gaskets? Try the fel-pro rubbeized type and do not feal bad this is a common 302 issue!mandra wrote:All of my 5.0's have needed replacement of the Valve cover gaskets. The one I am doing tomorrow is on my 85 ASC Vert. 18,895 miles and the VC is leaking like mad. Darn thing even has the original wires on it and they are fine. Is it just me?
-DAVID-
MY KEEPERS!
2003 SILVER MERCURY MARAUDER 320 HP 32V DOHC.
2013 FORD F150 RAPTOR "TERRAIN TAN" 4X4 CREW CAB & LIFT ON 37s.
2016 SHELBY MUSTANG GT-H HERTZ EDITION #82 OF 171.
1995 F-350 CREW CAB DUALLY POWERSTROKE FULL BANKS KIT!
MY KEEPERS!
So funny you should mention this. My car is in the shop right now getting this done. My motor was a nrw crate motor from previous owner too. There is no way I even put 1,000 miles on my car and I dont think he put much more on it either. My mechanic said it was fastened down to hard so it must have been from the factory. It was extremely clean under there too proving low to no use.
Nick
Nick
Yeah I've replaced mine...AND I've replaced my dads...AND I replaced the ones on my 79 5.0 notch...it seems like stock 5.0 valve cover gaskets always leak...
PetesPonies
