What type valve covers should my 85 have?
Rarecat
Post by Rarecat »
Soooo..... to summarize this, my 85 AOD CFI vert could have the finned PBF VC's if it's an early car or more likely black stamped steel w/Ford Oval? Do we have an idea of the possible cutover date range?
A previous owner put crome Moroso's on this car and it makes me sick to look at it...he also painted the intake red, that too shall be fixed.
1985 5.0 SC #137
2001 Bullitt Mustang
1967 Mercury Cougar
1968 Mercury Cougar XR-7
MHISSTC
Post by MHISSTC »
Maybe other folks with '85 cars can check their valve covers and build dates so we can narrow this down a bit. From the prior exchange, it appears the change from the finned cast aluminum "Powered by FORD" rocker covers to the stamped steel ones was made some time between October '84 and February '85.
Check this out. Click on the following link and scroll down the page to the March 1985 Popular Cars article about the 1985 Capri RS.
http://www.ascmclaren.org/phpBB/viewtopic.php?t=1449
"Powered by FORD"!
85 Valve Covers
My vert. with CFI, 5.0 & auto has black stamped steel valve covers. Not sure of the buld date. I think it says 2/14 or 2/19 in yellow in on the fender. The Special Equipment list says 2/13/85 and the incomplete vehicle manual say 3/85 for VIN 612205.
MHISSTC wrote:Maybe other folks with '85 cars can check their valve covers and build dates so we can narrow this down a bit. From the prior exchange, it appears the change from the finned cast aluminum "Powered by FORD" rocker covers to the stamped steel ones was made some time between October '84 and February '85.
"Powered by FORD"!
ALL 5 speed 5.0 1985 engines got the powered by Ford covers.
We are ONLY talking automatics here! The car in the mag article is a 5 speed!
MHISSTC
Post by MHISSTC »
negusm wrote:The car in the mag article is a 5 speed!
DOH!
How did I miss that?
Rarecat
Post by Rarecat »
Got a set of the Power by Ford covers, will look better than the Morosos even if it's supposed to have the stamped steel ones. I'm all about incremental upgrades. My car was modified by ASC in Feb 85....
1985 5.0 SC #137
1967 Mercury Cougar
S
Post by S »
mine has finned ones that say POWERD BY FORD if that helps
S
Post by S »
oh and its a manual car too. but its been modified a lot so ... could not be factory
Shaine wrote:mine has finned ones that say POWERD BY FORD if that helps
That is correct for your car. It is a carbed 5-speed car and they all got those.
S
Post by S »
sweet! something on the engine thats original :D thanks
