Rear spoiler & Altenator.
knsstang
Post by knsstang »
I was wondering if the rear spoiler on our cars are asc specific or do they match to another make or model car? also I have stopped at alot of altenator shops and they keep telling me they can't rebuild mine, but will sale me one with the built in regulator 100amps for 250.00. I would like to put the style i had back on( currently using stock mustang alt). Will one off of the Lincolns fit?
2012 GMC Yukon Denali (403Hp)
spoiler = asc only
i dont know if they sell to the public but... the shop i work for uses a place called import auto electric on telegraph and 9 mile or 8 mile. on the west side of the road. they are cheap and they will rebuild any alternator or starter
hanksgt
Re: Rear spoiler & Altenator.
Post by hanksgt »
I use Phoenix Generator Exchange (Phoenix, AZ). Dave the owner is very knowledgable. He said the Leestek is rated at 100amps but really only puts out about 50. We used a Delco back with the Leestek front half, and it has an internal regulator. He showed me how to make a plug so I didn't have to mod the car to make it work. The one he built puts out 83 amps on his bench tester. I kept all the old parts if I need to put it back to stock. It looks good and works great. And it was about $65 a few years ago.
knsstang wrote:I was wondering if the rear spoiler on our cars are asc specific or do they match to another make or model car? also I have stopped at alot of altenator shops and they keep telling me they can't rebuild mine, but will sale me one with the built in regulator 100amps for 250.00. I would like to put the style i had back on( currently using stock mustang alt). Will one off of the Lincolns fit?
wow sounds like a great guy and cheap
knsstang
Post by knsstang »
So the lesteck was not 130amps? How much is a stock mustang alt putting out? When I turn on my heat, press my brakes, turn up stereo or turn on wipers while the engine is under 2000rpm the needle goes below the center( shows discharge ). I need a stronger alt. How much do I need. I also have a question...How did asc attach the ground effects. Mine has double sided tape.
I wonder WHY did asc change the Alternator? Lesteck ?? Leestek?
Was not the standard 302 V8 Ford supplied Alt. enough ?
Seems odd.
hanksgt
Post by hanksgt »
Leestek shows a 100amp rating on the label (on my '89 unit), but they test out around 50amps. The stock Mustang unit puts out a rated 75 amps.
Someone on the design team thought they were doing well to go to all the work of changing it. I know Leestek does make some huge units for police and ambulance work and they much larger than our units.
As long as the idle is over 800rpm I can have everything on and it still shows charging on the plus side and thats only 85amps output.
knsstang wrote:So the lesteck was not 130amps? How much is a stock mustang alt putting out? When I turn on my heat, press my brakes, turn up stereo or turn on wipers while the engine is under 2000rpm the needle goes below the center( shows discharge ). I need a stronger alt. How much do I need. I also have a question...How did asc attach the ground effects. Mine has double sided tape.
ProTouringASC
Post by ProTouringASC »
Do remember to NOT trust your factory gauge. It's less accurate than the evening news! :shock:
Shiny Side Up!
hanksgt
Post by hanksgt »
I always use a digital voltmeter to show I have at least 13.6 volts running.
ProTouringASC wrote:Do remember to NOT trust your factory gauge. It's less accurate than the evening news! :shock:
Shiny Side Up!
knsstang
Post by knsstang »
The lestek was standard on the police package mustangs of our model year. I know what place you are speaking of on telegraph and 9mile, i went by there sunday to get the phone number but it was not listed on the door. I found a site online that sales them for about 150.00 with exchange. I have a discharge because my lights go dim
