Gas cap retaining strap attachment?
ChuckG
Post by ChuckG »
Okay, car came with an aftermarket fuel cap with no strap. Got an NOS Mororcraft cap with the dummy cord. Swap probably necessary because I'm probably the guy they designed the dummy cord for in the first place.
To what do I attach the cord? Which nut? Photos would be helpful.
Just because I filled up last night. The strap attaches in the bottom two holes. So the cap will flip open in the 6 o-clock position. Can send you a photo later if needed
ChuckG
Post by ChuckG »
I'll bring it tomorrow ;-)
Gas cap
The original cap had a flat strap which split and then connected to 2 screws. The later replacements had a round plastic strap that connected to 1 screw around the filler neck.
Original caps were gray and later replacements were black. I did see replacement straps at one time but they were for trucks. A nice original gas cap cap go for $100 these days.
ChuckG
Post by ChuckG »
Yeah, not a $100 to me. I can do without and keep looking at swap meets.
Here's what NPD sells.
https://www.npdlink.com/store/products/ ... -2457.html
I likely have a used one. I have see a couple. Just never payed much attention to them.
http://www.ascmclarencoupe.com/Parts/1985_Gas_Cap.jpg
This has a broken strap but it was original and you can see the orientation.
ChuckG
Post by ChuckG »
Scored one for $40. Not worth the grief to send anyone digging for that.
http://www.ebay.com/itm/Motorcraft-OEM- ... 2123030270
ChuckG
Post by ChuckG »
Also, are these the correct clamps for my hoses? How about what I need for the heater flex hoses for the air cleaner?
ChuckG
Post by ChuckG »
