Fender tag question.
86EuroCoupe
Post by 86EuroCoupe »
Sold a blue ASC Capri. Guy is tearing it apart and the fender apron tags do not match the vin. Both tags say ff111111. Buck tag is long gone. Door tag is gone. He has talked to the original owner and we know it's a true blue ASC. Trying to figure out the fender tag numbers and what they might mean. Any help would be appreciated
1985 Mercury Capri RS
2003 Ford F-150 Supercrew
Kendal Coker
capri
Post by Kendal Coker »
Check with Kevin Marti at martiautoworks.com. He has Fords database and is pretty good on body markings. You also can get a new door tag from him.
Kendal Coker
Yeah, not sure on the that tag. Maybe Ford made a mistake. I would say a number with all ones shouldn't be correct on the fender skirt.
I'd contact Kevin Marti for a report.
4-barrel Mike
Post by 4-barrel Mike »
I wonder if FoxChassis has seen this thread.
foxchassis
Post by foxchassis »
FF111111 = 1FABP28MXFF111111 (1985 Mustang 5.0L hatchback)
With the buck tags and door tag gone, and both fender tags being the same but not matching the VIN on the firewall, I'd say you're looking at a front clip swap or a re-body.
4-barrel Mike
Are you sure, Mick? :shock: Mustang fenders on an '85 ASC Capri? :wink:
4-barrel Mike wrote:Are you sure, Mick? :shock: Mustang fenders on an '85 ASC Capri? :wink:
the Fender tag is really not connected to the Outside fender. its welded to the frame rail or inner fender apron
4-barrel Mike
Ah! Thanks.
