Mind if we take the cam out to check and prove it once and for all?Sandy wrote:Remember....I have 688 miles. Not too much could be wrong.
Picture of my wreck in 1993
- 86capriasc
Hehehehehehe,
That will never happen.
- 86capriasc
I didn't notice any other marking on the cam. But remember the motor had 100k on it so anything that was on was probably worn off.
I also wonder if there was any issues with these cams, that maybe the original owners may have had them replaced.
1986 ASCMclaren #108
stock E7 short block, explorer intake, 65mm TB, home built Gt45 turbo kit, 3.08s, Borla cat-back, '05 slot maf, Gt-40p heads, TFS1 cam, 80lb injectors, E85, Qaurterhorse tuner.
- 86capriasc
I'm thinking that mine is not a B303 by looking at it. I have looked at other pics were there is a m6250 stamped into the end. Mine does not have that. Maybe being installed at asc or ford they didn't have that stamping though. You can see the drawing off the stampings in my album.
- 86capriasc
- 86capriasc
Do you have a caliper? Can you measure one of the lobes from heel to toe?86capriasc wrote:Not sure. That may have been there when taken out.
I have a B303 (2 actually) and can do the same measurement. This would tell us if the lift is the same.
- 86capriasc
