86 coupe tire sizes /lowering
ckj
Post by ckj »
What is the correct tire size for a 86 coupe? P225/50x15?
What tire sizes are others using with the asc mclaren rims?
I was thinking about lowering the car 1 -1.5 inches with H&R super sport springs, any feedback?
Thanks,
Ryan
ckj
Post by ckj »
Well I went and ordered some new tires. Too bad you can't order the comp t/a anymore. I went with the 225/50/15 bfgoodrich g-force sports...
http://www.discounttire.com/dtcs/findTi ... V7&rf=true
I didnt know you could still get 225/50/15's looks like a good deal.
My friends lowered mustang and ASC/AR blk wheels
He runs these on the rear great for racing and street running http://www.discounttire.com/dtcs/findTi ... &tc=NITHV4
And these on the frt
http://www.discounttire.com/dtcs/findTi ... &tc=MTAHS1
They work very well and it hooks and go's :wink: when need.
I also plan to run the same rear tire on my GPIV
scoutdrivinrebel
Post by scoutdrivinrebel »
Ok guys, what should I go with. Stock? She currently has P 225/50 R15's on the front, and P265/50R15's on the back. I like the look of the rear tires. Would it be pushing it to go with P265/50R15's all the way around. I assume they'll rub up front. Stock just looks tiny.
scoutdrivinrebel
scoutdrivinrebel wrote:Ok guys, what should I go with. Stock? She currently has P 225/50 R15's on the front, and P265/50R15's on the back. I like the look of the rear tires. Would it be pushing it to go with P265/50R15's all the way around. I assume they'll rub up front. Stock just looks tiny.
Nevermind, doesn't look like 265's are even available anymore. I wonder how old my tires are? Geez, guess I better order some. CKJ, how do you like yours?
i plan on getting a new set of 225/50R15 this summer. i think you can buy a 255/50R15.
I ran 245 50 15s on mine years ago, but you'll have to change your speedo gear. Not sure 255s will fit.
If I recall, your rolling diameter would pretty much be equal to the stock 3.08 running 225 60 15s.
rod442
Post by rod442 »
I run 275-50-15 nitto drag radials with no rubbing. lowered w motorsport B springs.
some people have had to flip the quad shock around to make it work (I didn't); or remove them entirely if you have aftermarket rear upper and lower cont arms.
rod442
2005 Saab 92x SAABARU
2003 Yamaha R1 RRATED
2000 Formula m6 INCONTT
1988 Mustang LX 5LTRLX
"Stock" is my middle name.
"Original" is my nickname !
"Aftermarket" is where 'ya go after you been food shopping. :wink:
bigzeke42
Post by bigzeke42 »
I run the 225/60/15.....stock.
Zeke 86 Eurocoupe
rod442 wrote:I run 275-50-15 nitto drag radials with no rubbing. lowered w motorsport B springs.
I :love: this tire, Rod has loaned them to me and I think the pavement stuck to the tire. If you wish you had more traction everytime you drive this is for you. Plus they look TUFF
