Rear Carpet - OEM Material
351mclaren
Post by 351mclaren »
Is the rear carpet just a normal grade acc style carpet or did asc do something different? It seems to be a slightly thinner carpet(the rear compartment area)...Is that because the carpet on the floor has the noise deadener?
Sandy, Mike or others, please tell me you have the beige material code and a fabric store that I can locate it.
You don't need a code. I wouldn't give it to you if I had it anyways.
What you need to do is get swatch material from the place you want to buy it from. They will send you samples and you need to pick the best one.
Stay away from ACC as they make junk. Go with Trim Parts Carpet. Trim Parts is much better quality carpet and sold by FoxMustangRestoration.com. You can call them, they are quite knowledgeable and explain what you are trying to do. Mention FourEyedPride.com for a 10% discount.
Either way GET SWATCHES! There are no manufacturers out there that make carpet colored just for the Mustang. It's general purpose carpet thrown in a mold. They will do any color you want but don't really know the correct match. Ask for 3-4 swatches of the closest colors and match it up.
If you want exact oem stuff, you might want to contact Hank in Florida (www.ascmclaren.com) and ask if he has some NOS around.
