Attaching Vinyl Cover To Tonneau
AZCruisen
Post by AZCruisen »
I have searched the site and found numerous discussions on replacing this piece, but no where did I see what to actually use to glue it down. I am currently replacing my torn and worn blue vinyl and would like to know what is recommended to glue this fiberglass piece back down. Thanks.
http://www.ascmclaren.org/phpBB/viewtop ... over+nails
Someone used some 3M tape.
I'd probably use some liquid nails AND some 3M body tape.
http://solutions.3m.com/wps/portal/3M/e ... ched_Trim/
bigzeke42
Post by bigzeke42 »
I'd try contact cement.
Zeke 86 Eurocoupe
85asc239
Post by 85asc239 »
To glue blue vinyl back down to fiber glass -good 3m spary adhesives works.
To glue fiber glass peice back down to car - structural adhesive- can be had at lowes. Comes in culk tube, can lay down nice thick bead. Does not run. Works great.
Jeremy
Epoxy for Bonding
Hi Guys
Do not use contact cement or adhesive in tube
I sell adhesives, for this project use Loctite E-60HP
Part number 29319
Off White in color
Viscosity 45,000
Mix rate 2:1
60 minute work life
Fixture time 180 minutes
Cure Time 24 hours
Temperature Resistance 250 F ( 121 C)
Shear Strength 4,320
Purchase from Fastenal Grainger, Motion industries, or MSC
Hope this Helps!
Thanks Chris
thought this would be up your alley :wink:
