86?
mpduncan35
86?
Post by mpduncan35 »
Mason Duncan
1984 #30 vert
1985 #282 vert
1986 #48 vert
1986 #40 coupe
1987 Bronco ii Motor Trend concept
Re: 86?
Ouch. How sad.
I did move your post from the registry section since we don't have the VIN on this one.
Re: 86?
More images:
Re: 86?
Kind of hard to tell if its an 85 or 86. GT dash bezels, no door panel arm rests, no signs of the 3rd brake light, cannot see the engine to see if its a v6. What are the cross braces in the trunk?
My guess is 86 and v6.
There are definitely way too many ASC parts present to be a regular Capri.
Re: 86?
I did not see anything like this one on my spreadsheet. Most white ones were in CA, had recaros, repainted from blue or spotted by an actiive member recently who would have recognized it. It doe appear to have a plaque on the rear fender.
mpduncan35
Re: 86?
Yeah who ever ends up buying it will hopefully share the number and if it is a V6. But there is no much you can use off of it. And would be a lot of work to make it driveable, and V6 would scare away most buyers.
Mason Duncan
1984 #30 vert
1985 #282 vert
1986 #48 vert
1986 #40 coupe
Re: 86?
That vacuum canister in the fender. Is that used on an 86? I know my 85 had it. If they had taken a pic of the engine bay, we'd know for sure.
Re: 86?
I'm certain my 84, 85,85,88 and 89 all have the same vacuum canister. AC cars would have it. Its pretty hard to see under the hood. I think the vacuum hose routing to it may have changed. My 86 seems to pass through in front of the strut tower. As for the canister, only the mounting screw would be visible from under the hood.
I have not see my sun visors in years as they were removed for visibility. I'm guessing 86 had vanity mirrors and not 85. My 86 mustang vert has mirrors. My 84 mustang vert does not. My guess is this car is an 86 model year.
