Electric trunk lid release
dndzol
Post by dndzol »
I have a 1985 ASC convertible. I removed the Ricaro seats and after reinstalling them the trunk will not release from the glovebox button. Where do I start to look for a solution?
75coug
Post by 75coug »
Good question. My trunk release recently stopped working as well.
Robert
1984 ascMcLaren convertible - white
03Mach1
Post by 03Mach1 »
Might be a stupid question but you do have your key in the ignition with it turned to the on position just before it cranks the engine? Mine has to be in the on position before it will work.
'88 ASC/McLaren #542 white/gray/black 20,000 miles trailer queen
'03 Mach 1 torch red 7,500 miles trailer queen-sold
'06 King Ranch F150 white over gold/saddle 34,000 miles-mustang hauler
75coug
Post by 75coug »
03Mach1 wrote:Might be a stupid question but you do have your key in the ignition with it turned to the on position just before it cranks the engine? Mine has to be in the on position before it will work.
I tried every possible combination, to no avail.
Robert
toddf
Post by toddf »
If I recall correctly, the trunk release gets its power through the seat heater circuitry.
Electric Trunk Problem
Post by capri50asc »
Get a test light, Clip the ground to the body, thenplace the tip of the tester on the positive lead. Have someone push the button and see if the light comes on. If it does you have a problem with trunk latch. If the light does not work. remove the switch from the glove box or console. Test the lead to the button. If you have power, then the lead to the trunk is open (bad) or you have a bad button. If you have no power , then check the fuse under the dash. If the fuse is good then check one side of the fuse box for power. It could be a bad wire to the fuse box or a bad wire to the trunk release button.
Good Luck Chris :)
Havoc
Post by Havoc »
BTW other than buying a new release from hank for 75.00 where else can I find one of these? What other model cars use this release?
1986 White vert McLaren# 196
toddf
Post by toddf »
you can order one from a local auto store, it is the same as a trunk release for an 86 camaro. You can get the plastic cover for around 30, the entire assembly will run around 70.
KHummel66
Post by KHummel66 »
You can find them on ebay fairly readily for around $30 complete - it's actually the trunk pull down motor from an early-80's Caddy.
