Electric trunk lid release
I have a 1985 ASC convertible. I removed the Ricaro seats and after reinstalling them the trunk will not release from the glovebox button. Where do I start to look for a solution?
Might be a stupid question but you do have your key in the ignition with it turned to the on position just before it cranks the engine? Mine has to be in the on position before it will work.
'88 ASC/McLaren #542 white/gray/black 20,000 miles trailer queen
'03 Mach 1 torch red 7,500 miles trailer queen-sold
'06 King Ranch F150 white over gold/saddle 34,000 miles-mustang hauler
I tried every possible combination, to no avail.03Mach1 wrote:Might be a stupid question but you do have your key in the ignition with it turned to the on position just before it cranks the engine? Mine has to be in the on position before it will work.
Robert
- capri50asc
Electric Trunk Problem
Get a test light, Clip the ground to the body, thenplace the tip of the tester on the positive lead. Have someone push the button and see if the light comes on. If it does you have a problem with trunk latch. If the light does not work. remove the switch from the glove box or console. Test the lead to the button. If you have power, then the lead to the trunk is open (bad) or you have a bad button. If you have no power , then check the fuse under the dash. If the fuse is good then check one side of the fuse box for power. It could be a bad wire to the fuse box or a bad wire to the trunk release button.
Good Luck Chris
Good Luck Chris
You can find them on ebay fairly readily for around $30 complete - it's actually the trunk pull down motor from an early-80's Caddy.
1986 ASC vert - #86-0001
1986 ASC vert - 3.8SC v6
1986 ASC vert - Silver/Black/Gray
1985 ASC vert - Black/Tan/Tan
1985 GPIV - The Official Pace Car
1985 ASC coupe - modified
1985 ASC coupe - roller
1983 Crimson Cat V6
1966 Cobra replica
1983 Crimson Cat V6
1966 Cobra replica
