convert electrical
Dr Cobra
convert electrical
Post by Dr Cobra »
Has anybody put the tonneau cover solenoid on a different switch from the pull-down motor so that the solenoid isn't energized while the pull-down is running? This would give the motor more voltage to run.
1989 McLaren #150
1988 Mustang coupe-351W-88mm turbo
tfs2121
Post by tfs2121 »
http://www.ascmclaren.org/phpBB/viewtop ... t=solenoid
This is all I could find but I thought I remember someone doing exactly what your talking about.
1985 ASC McLaren Coupe
Dr Cobra
Post by Dr Cobra »
Thanks, I was thinking of using another switch hidden under seat maybe to control solenoid, but I will look into using a timer also.
1989 McLaren #150
mrheehee
Post by mrheehee »
I did eventually replace the pull-down motor, and the top. But I left the timer circuit in place and it still works great, no other switches necessary.
Dr Cobra
Post by Dr Cobra »
mrheehee wrote:I did eventually replace the pull-down motor, and the top. But I left the timer circuit in place and it still works great, no other switches necessary.
Can you provide a little more detail on the timer you used ?
1989 McLaren #150
mrheehee
Post by mrheehee »
It is an SSAC Time Delay Relay, 12V
