84 Roadster on eBay
86MclarenCapri
- Contact:
84 Roadster on eBay
BEAUTIFUL CAR!!
What a difference it makes between the inside and outside pictures!
84 Roadster on eBay
But, there are a few modifications that I'm wondering about.
I thought the ASC ground kit wasn't offered until 85 or 86, so it has been added? Was the decklid spoiler available on the Capri's?
The rear valance doesn't look right, it looks like it doesn't come up to the back of the wheel wells far enough. The cut-outs have been enlarged to take the dual exhaust tips.
Everything is painted red-- are the headlight buckets and all of the grill supposed to be painted to match the car? the 5.0 SC logo in the grill is obviously painted.
Also, the 'fins' on the tail lights are painted red. I'm not sure I like that, but it is different.
The tonneau doesn't fit well, that is a bummer.
There are several plastic push-in clips holding the tonneau cover to the tonneau. I have several clips like that, but I thought it was just glued down. Are the clips correct??
84 Roadster on eBay
Dan
Norfolk, VA
67 Mustang GTA Convt
Norfolk, VA
4-barrel Mike
4-barrel Mike
Not really sure how to take that? I was just pointing out some observations. My 86 brake pedal with 99k and a manual has less wear. And I bought new in High School. Its a lot of time and money went into that car and would be hard to do for 15KKentennis wrote:Plum Crazy. Glad you can help so much. I didn't really look closely. I'd be glad to have you critique mine before I put it on Ebay!!
The side mouldings give it away.
It is an 84 that the outside has been almost completely updated to an 85.
None of the rub mouldings should have the 2 pencil thin grooves in them and you can see that the one marker reflector moulding has the 84 profile.
I am guessing that the car needed a fair amount of body work and they went with an 85/86 update on the outside.
But for 84, no ground effects like that came on the cars that I know of.
lightning95sc
- capri50asc
- Contact:
Oil Burner
Yes, It does burn oil , I would say its 167,000 miles on it and the valve guides are gone. But what do you want for a re manufactured car, its been pieced together . Also note is the passenger door does not match and the deck lid. Looks like a checker broad
Its a $4500-$5,000 car
Chris
Chris
