Shock Tower
Shock Tower
On my 86 Eurocoupe is it common to have rust on the shock towers? And if so how do you fix them and how hard?
Zeke 86 Eurocoupe
Where exactly? Top or bottom?
If the rust is superficial: sanding, rust remover, priming and painting can be done.
If it has gone through. It'll need a patch welded in.
If it's ROTTEN down by the base frame rail...you're looking at some structural repairs and you'll probably need to yank the engine and really have somebody repair that spot correctly.
It is very common for the cars to rot out on the frame rail and it can get pretty devastating (not to mention unsafe).
- capriman86
- capriman86
Thats not good,, I hate to say it but pulling the engine is your best bet if you want to fix it. You may find after pulling the engine that you could weld some steel over it but to Fix like factory will be a BIG job. And may want to find a whole clip. If it was me I would Drive it and not worry or Sale and find a Cleaner car. Sorry! but i think other would agree. I'm going thru that with a 1985 stang right now.
I'm wondering how safe it is to drive and for how long? I just noticed the rust when I had the valve cover gaskets installed.plumkrazy wrote:Thats not good,, I hate to say it but pulling the engine is your best bet if you want to fix it. You may find after pulling the engine that you could weld some steel over it but to Fix like factory will be a BIG job. And may want to find a whole clip. If it was me I would Drive it and not worry or Sale and find a Cleaner car. Sorry! but i think other would agree. I'm going thru that with a 1985 stang right now.
Zeke 86 Eurocoupe
People often have these issues. 2 Options occur to me. I have seen many have them boxed. They cut out the rusted area, treat the remaining metal and put a nice piece of steel over the rail. If it is done professionally it will last for years without issue and won't look too bad either. The other option is to replace the frame rail. The issue with this is that it is a lot of work and if not done well can be detrimental to your nose alignment.
Best of luck
Best of luck
